Date/Time: Mon, 25 Nov 2024 14:35:00 +0000
getting an error when replay with no attached trade window
View Count: 1116
[2014-02-15 21:27:31]
ariknoi - Posts: 31
i am trying to replay and getting this
Trade Order Error: The order quantity for the Parent is 1 and this is less than the total order quantity of 3 for the Attached Orders. Please adjust the order quantities so the parent is greater or equal to the Attached Orders. | 2014-02-15 16:06:34
no where in my code i sent quantity of 3 (though when used the attached trade window i had a bracket of 3)
pls advice
thanks!
[2014-02-15 22:17:44]
Select Trade >> Open Trade Window for Chart. Uncheck the Use Attached Orders option.
[2014-02-16 06:23:03]
ariknoi - Posts: 31
thanks, yet it's not working
pls check the screen capture where you can see it's unchecked and yet the same error is given
thanks
image16-02-2014 08-19-24.jpg / V - Attached On 2014-02-16 06:22:09 UTC - Size: 2.62 MB - 398 views
[2014-02-16 09:01:53]
This is very unusual. We could not duplicate the issue.
Does the "No Match" error at the top of the Trade Window go away if you enable Use Attached Orders and disable it after.
[2014-02-16 11:45:40]
ariknoi - Posts: 31
tried this as well and didn't worked out.
can i send you my code in private pls?
[2014-02-16 19:41:46]
Is an ACSIL trading system or a Spreadsheet trading system?
[2014-02-16 19:44:44]
ariknoi - Posts: 31
ACSIL
[2014-02-17 07:04:06]
Could you provide us a simple code example which can reproduce this problem. We cannot work with your complete study function, but just a simple example.
