Date/Time: Thu, 13 Feb 2025 07:21:19 +0000
"Chart Selected Tab Color" when sierra is not in focus
View Count: 468
[2020-12-01 14:55:18]
samual sprat - Posts: 343
I've set "Chart Selected Tab Color" and "Chart Tab Color" to different colors. In windows if sierra is the application in focus, then the "Chart Selected Tab Color" works as it should. However if Sierra isn't in focus, then "Chart Tab Color" is active and you cannot see which tab is actually selected.
It's a small thing, but it's frustrating when you multi monitors and want to quickly know what you're looking at and have to click on sierra application to see.
Note - "Chartbook Selected Tab Color" works as expected when sierra is not in focus, so I'm guessing this is just something that was overlooked
Thanks,
S
Date Time Of Last Edit: 2020-12-01 14:56:24
[2020-12-01 15:29:45]
Just realised. This isn't happening when sierra loses focus, it happens when a detached chart from the same chartbook is selected. So I guess the detached chartbook is gaining focus and becomes the "Chart Selected Tab Color". However the logic of this is still incorrect, can it be changed if possible?
Date Time Of Last Edit: 2020-12-02 08:23:38
