Date/Time: Sat, 31 Oct 2026 08:01:05 +0000
REPLAY DOM CHART PRICES NOT SYNCING
View Count: 1081
| [2020-12-01 13:05:14] |
| User762875 - Posts: 7 |
Hello, I'm currently on chart 6EZ20_FUT_CME and when I try to chart replay back to the beginning of the chart,2020-11-01 at 18:59:59, the Dom prices are incorrectly synced. Showing pricing of 1.19735 instead of the pricing at that time which is around 1.16520. I also went to the help tab to download the current version but it is still giving me this error. Please help |
| [2020-12-01 15:15:07] |
| John - SC Support - Posts: 48377 |
Which DOM prices are you referring to? If this is the Chart DOM, then keep in mind that it is always showing you the Last price of the last visible bar in the chart. Therefore, as long as the current bar is visible, it should be in sync with the replay. If, this is a separate Trading DOM, then the easiest thing is to replay all charts in the chartbook to ensure that you are also replaying the Trading DOM. Refer to the information here: Replaying Charts: Replaying Trade DOM Windows For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
