Date/Time: Mon, 25 Nov 2024 14:48:11 +0000
Replay mode
View Count: 1019
[2014-02-15 20:33:52] |
Fxxtrader - Posts: 79 |
Hello, When selecting date range to display on a chart, for replay, either by "Use Number of Days to Load" or "Use Date Range," after clicking OK, the results show the end of range period first. To see the start of the range, I need to scroll to the left. Is it possible to have the chart display the first bar of the selected range instead of the last bar of the selected range, in replay back mode, after clicking OK? This would give two advantages. First, it would be quicker to begin replay, less set up required. Second, when scrolling from end of period range to beginning of period range, I see the price levels which I don't want to see. Thanks in advance for any response. |
[2014-02-15 21:03:14] |
Is it possible to have the chart display the first bar of the selected range instead of the last bar of the selected range, in replay back mode, after clicking OK? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
