Date/Time: Mon, 25 Nov 2024 15:00:45 +0000
Line on close colour
View Count: 1574
[2014-02-15 20:29:46] |
markyboy67 - Posts: 5 |
I'm trying to create a correlation chart with four different symbols via the overlay facility. This is fine. However, when i come to change the colour of the line on close for each individual symbol there does not appear to be a facility to do this & it's only a graphic setting which changes all the lines...............surely this is an oversight on my part & the software is capable of doing something so basic? Thanks |
[2014-02-15 21:04:22] |
Refer to this page: https://www.sierrachart.com/index.php?l=doc/doc_GraphDrawTypesColorSettings.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-16 11:04:47] |
This was typical, as soon as i'd raised the question I found out how to do it. Thanks for the response though. |
