Date/Time: Wed, 26 Feb 2025 23:37:50 +0000
MakeHTTPPOSTRequest to send JSON body
View Count: 1097
[2020-11-30 15:34:21]
kam2001 - Posts: 79
Is it possible to make this method (MakeHTTPPOSTRequest) to send JSON (application/json) as part of the body instead of application/x-www-form-urlencoded ?
and also how can we retreive response headers from sc.HTTPResponse.
Thanks,
Kam
Date Time Of Last Edit: 2020-12-01 10:48:12
[2020-12-01 19:02:02]
We will have to look at this when we can but we really recommend just doing these HTTP requests outside of the ACSIL interface. Have a look at using curl.
[2020-12-02 14:29:05]
kam2001 - Posts: 79
Thanks, i am not sure what you mean by using Curl. I understand curl is way to transfer data and can also be used for http protocol, are you saying curl is supported in ACSIL interface.
My set up is that i've got an external broker where i need to send json body and retrieve key from response headers to make any subsequent calls. Currently i am making a call from sierra to my own app which accepts application/x-www-form-urlencoded from sierra and than converts it to json and sends a curl request to broker. The reason for this request from yourself was so i can cut out the middleman (my app) and make a call straight from sierra by sending json.
Date Time Of Last Edit: 2020-12-02 14:30:52
[2020-12-30 22:18:25]
Sierra_Chart Engineering - Posts: 18574
There simply is no support in ACSIL to access HTTP headers but there is a way to specify headers with the request by using this function:
int (SCDLLCALL* MakeHTTPPOSTRequest)(const SCString& URL, const SCString& POSTData, const n_ACSIL::s_HTTPHeader* Headers, int NumberOfHeaders);
We will be sure to prepare some documentation for this to explain how it is used.
Date Time Of Last Edit: 2020-12-30 22:18:47
