Date/Time: Thu, 13 Feb 2025 07:59:05 +0000
Subinstance - not connecting on startup
View Count: 513
[2020-11-30 10:04:01] |
User495158 - Posts: 108 |
Since I updated to v2204 the subinstance does not automatically connect to the data feed on startup. I have to manually press connect. Any idea why? I didn't change my settings (see screenshot). Thanks |
[2020-11-30 10:21:10] |
This has been resolved. Update Sierra Chart again following these instructions: Software Download: Fast Update The version number remains the same. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
