Date/Time: Thu, 13 Feb 2025 07:34:04 +0000
intraday chart
View Count: 500
[2020-11-30 09:23:15] |
szdaniel1994 - Posts: 18 |
Hi SierraChart support, It seems something is wrong with the intraday chart because it is different than the historical - also different from the chart from tradingview/finviz. Could you please advise how we can solve the problem? Thank you! |
![]() Attachment Deleted. ![]() |
[2020-11-30 09:45:40] |
What is the difference you are seeing specifically? Refer to this page: Differences With Data and Chart Bars Between Services / Connections / Chart Types And refer to this subsection: Historical Chart Prices: 12.11 - Differences with Historical Data Due to Dividend Adjustments Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-30 09:45:55
