Date/Time: Thu, 13 Feb 2025 07:57:30 +0000
Cannot modify stationary text settings of existing drawings in OpenGl mode
View Count: 777
[2020-11-30 03:16:11]
User845052 - Posts: 75
above
[2020-11-30 06:53:01]
I don't know but this may have something to do with the last update. I put it back in normal graphics mode and I still cannot access the drawing settings (lock, unlock text). It's too coincidental.
[2020-11-30 07:00:11]
Nevermind I just had an idea and realized I could find the settings through Chart Drawing Properties menu item. The same thing was accessible through Modify Text just yesterday, so something must have caused this frustratingly sudden nuance. Problem solved I guess
[2020-11-30 17:56:02]
John - SC Support - Posts: 37916
Modify Text will only allow you to modify the text of the drawing. The other properties have to be gotten to through the Chart Drawing Properties. It has always been this way and has not changed. You will find the documentation related to this here:
Chart Drawing Tools: Chart Drawing Properties
[2020-12-01 09:32:35]
Alright, but I was accessing it through Modify Text before. Even if that it supposed to be impossible, it was the case. I never had Chart Drawing Properties on my menu shortcuts until this occurred. That is how it is
