Date/Time: Thu, 13 Feb 2025 06:48:19 +0000
which package needed to use bitmex conection
View Count: 649
[2020-11-29 02:51:52] |
User295020 - Posts: 1 |
Right now I have an account with sierra by AMP futures, where I trade, I want to connect as well to bitmex where I also have an account and says 'no package available' I guess that is because the AMP version is light. So, which package I have to pay to have both bitmex and amp (via cqg) connections enabled? thank u |
[2020-11-29 04:57:18] |
You need the Standard Sierra Chart Service Package but a Direct account. Direct Sierra Chart Account When you are using Sierra Chart that has been provided through an affiliate, you do not have a direct paid account with us, and you wish to access functionality that is not provided in your limited version, you must have an account with Sierra Chart directly and have a standard installation of Sierra Chart. To accomplish this, follow the instructions below: Direct Sierra Chart Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-29 04:57:27
