Date/Time: Thu, 13 Feb 2025 07:39:22 +0000
Missing times on Forex charts
View Count: 545
[2020-11-28 17:03:56]
User92899 - Posts: 76
Hi
In an update to current version today the log reported an error. When I ran the program all my chartbooks were there, but on the Forex chartbooks there was just 00.00 across the time/date axis and no response from our custom study. The other studies/charts appeared normal.
I reloaded an older version and everything worked as expected.
Any thoughts? I did send a log but don't know if it reached you.
[2020-11-29 20:22:24]
Do you see this problem when you run Sierra Chart in Safe Mode in the current version:
Sierra Chart - Software Login Instructions: Using Safe Mode
[2020-11-30 08:14:57]
No - the date/time axis is normal in safe mode. So does this mean there is an issue with the DLL?
I had a new customer yesterday with an error in getting our files - has something changed that requires our stuff to be recompiled again?
[2020-11-30 08:16:52]
here's a screenshot image from the user's error yesterday
Private File
[2020-11-30 10:30:30]
Possibly the custom studies you are using are affected by the change with some ACSIL functions in version 2195:
https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2195
But that will not affect the chart timescale unless the study is incorrectly modifying the timescale which it should never be doing.
[2020-11-30 10:45:08]
What's odd is that we have 3 different custom studies (Indices, Forex and Commodities) and it's only the Forex one that seems to be affected.
However, the new user error message attached was a different issue I think and I wondered what you thought about that?
I will ask the developer to check through the DLLS to see if there is any issue there.
