Date/Time: Thu, 13 Feb 2025 07:20:13 +0000
[User Discussion] - Combining study collections
View Count: 1025
[2020-11-26 20:02:45] |
amirN - Posts: 159 |
How can I combine two charts (same symbol) into one without adding every studies in one chart into the other? Or how can I combine two study collections?
[2020-11-26 22:52:07] |
ForgivingComputers.com - Posts: 1001 |
When you save a Study Collection, check the box for Prompt to Remove Existing Studies. Then you can add as many study collections as you want. The only problem with adding study collections is the ID numbers can be renumbered if already in use, and references to those IDs are not renumbered. This can break connections between studies. If you are careful it can be done.
[2020-11-30 16:32:12] |
ycomp - Posts: 321 |
is there a way to set the ID # of the study?
[2020-11-30 18:12:14] |
Not directly. You can duplicate and remove studies, and in the process free up ID numbers, so that the next study to be added or duplicated takes the lowest un-used numbers. |
