Date/Time: Tue, 26 Nov 2024 15:37:24 +0000
[User Discussion] - Pivot Range Study plotting issue
View Count: 593
[2020-11-25 19:05:23] |
Dt111111 - Posts: 5 |
Hello, I have run into an issue with the plotting of the Pivot Range - Variable period study. I believe it is because of the way you have to tell it to use 0-100% of a timeframe for it to calculate. So if I do Period - Day, % required - 100%, then I would get a Pivot Range every day at the new session say on ES at the 18:00 EST open I should have a new range. The problem is Monday. It will not calculate a range from monday because I assume it is unsure how to incoporate Sunday data in that % or SUnday may not count as a full %. How do I get it to just use Friday's while also having it work for the rest of the week Monday forward? The same issue occurs with any spot currency. It doesn't understand how to filter the Sunday Data. And it is worth noting I'm using a daily chart as the base and then using the study overlay to put the pivot range onto an intraday chart. I have had this same issue with other studies that use the same % of time period parameter to build the study. Thanks. |
[2023-11-11 10:17:08] |
User953016 - Posts: 3 |
Hi Sierra, this question has come up a few times and I am wondering how to resolve it, please can you assist? How do you get your Pivot Range - Variable period study to appear on a Monday? Thank you |
