Date/Time: Mon, 25 Nov 2024 14:44:17 +0000
automatically create chartimage and save to file
View Count: 1133
[2014-02-15 11:53:26] |
sbsierra - Posts: 71 |
hi, is there any study to periodically save a chartimage to a given folder? thx. SB |
[2014-02-16 01:37:18] |
No, but refer to this page for what is offered: https://www.sierrachart.com/index.php?l=doc/doc_Image_to_Server.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
