Date/Time: Thu, 13 Feb 2025 07:43:13 +0000
Volume by Price profile smoothing
View Count: 649
[2020-11-25 14:19:39]
User350195 - Posts: 34
is it possible to add Volume Profile Smoothing so it's easier to see profile shape patterns and have a cleaner view?
just like the attached screenshot
Thanks!
imageimage.png / V - Attached On 2020-11-25 14:18:00 UTC - Size: 61.88 KB - 218 views
[2020-11-30 12:56:30]
ochocinco - Posts: 29
For VbP smoothing I use the VbP's 3rd input: Ticks Per Volume Bar
You can set it directly via each study or for the entire chart via the Chart Settings: Volume at Price Multiplier
(note setting at the chart level will probably have a similar effect of smoothing on other studies, on that chart, which rely on volume at price, but you'll have to test)
[2020-11-30 14:09:03]
Thanks, but it's not the same. Increasing ticksize will lead to destruction of profile patterns.
