Date/Time: Thu, 13 Feb 2025 16:10:20 +0000
i use dorman trading , how to subscribe HKEF (MHI)
View Count: 751
[2020-11-25 02:35:15] |
User587476 - Posts: 29 |
Q1:i use dorman trading , how to subscribe HKEF (MHI), Q2:if can't connect CHINA Future market , then can i diy API ,Make the connection to CHINA Future market, at last Most hope to be able to connect the Chinese market by Sierra Chart thank you for you help. Best Regards, |
[2020-11-25 15:22:58] |
For Hong Kong futures data, you can get that data as part of the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed We are intending to add support for the Chinese futures markets. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-12-14 02:07:40] |
User897008 - Posts: 48 |
Looking forward to supporting the Chinese market soon.
