Date/Time: Thu, 13 Feb 2025 07:26:11 +0000
The Problem with the Australian dollar charm.
View Count: 601
[2020-11-24 21:22:17] |
2garin - Posts: 184 |
Good day. See how the chart of the Australian dollar futures contract is displayed. Thanks.
[2020-11-24 21:37:22] |
We really do not recommend using CQG data which is the source of this issue. We recommend that you use the Denali Exchange Data Feed: Denali Exchange Data Feed Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-24 21:37:38
[2020-11-24 21:53:07] |
The problem persists.
[2020-11-24 21:53:44] |
[2020-11-24 21:58:34] |
The terms of the contract were not clarified?
Date Time Of Last Edit: 2020-11-24 22:01:48
[2020-11-24 23:00:20] |
2196 historical data during the break 2196 2 chart after the opening of trading Date Time Of Last Edit: 2020-11-24 23:10:02
[2020-11-25 15:34:42] |
There was definitely a problem with the data from CQG and we have now cleaned up the data errors for the symbol on the server. Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Also refer to an upcoming change related to CQG historical data: Changes to Historical Intraday Data for CQG and Interactive Brokers (January 1, 2021) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-25 15:36:22
