Date/Time: Thu, 13 Feb 2025 03:45:51 +0000
[User Discussion] - ACSIL: Can't change my int SCInputRef to a float or double
View Count: 680
[2020-11-24 18:56:29]
ycomp - Posts: 321
I have this weird behaviour... I had an SCInputRef that I used as an int. I mean Set/GetInt(), then I changed it to Set/GetFloat().. I also tried Set/GetDouble() but either way I cannot use the UI of the studies dialog to enter a non-integer number. This is after removing the study and adding it back in even.
Any ideas why this happens and how I can fix it?
note: ValueFormat is 2 (0.01) so that is not the problem
note2: I use Float or Double Limits of 0, 1000
Date Time Of Last Edit: 2020-11-24 18:57:32
[2020-11-25 13:29:43]
ycomp - Posts: 321
strange, today it is working
