Date/Time: Thu, 13 Feb 2025 03:28:49 +0000
DATA BOX WITH BAR INFO FOR OHLC
View Count: 901
[2020-11-24 16:21:57] |
User910795 - Posts: 35 |
I HAVE ALWAYS HAD A BOX THE POPS UP WHEN I HOVER OVER A BAR AND IT GIVES ME THE OHLC AND SOME OTHER DATA. IT HAS GONE AWAY AND I DO NOT KNOW HOW TO GET IT BACK. USE IT ALL THE TIME. CAN'T BELIEVE IT LEFT ME.... HELP
[2020-11-24 16:25:17] |
Ackin - Posts: 1865 |
Show Compact Tool Values Window (Sierrachart / Menu / Window) Window, CB and CW Menus: Show Compact Tool Values Window (Window) Compact Tool Values Window Chart Drawing Tools: Compact Tool Values Window Date Time Of Last Edit: 2020-11-24 16:27:49
[2020-11-24 16:42:19] |
John - SC Support - Posts: 37916 |
As Ackin notes above, you are looking for the Compact Tool Values Window. In case it still does not show up after you select it from the menu, refer to the following to reset the window position so it forces it to be back within the visible area of your screen: Chart Drawing Tools: Compact Tool Values Window Not Visible For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
