Date/Time: Mon, 25 Nov 2024 14:53:54 +0000
sc.DLLNameUserServiceLevel upper bound
View Count: 1115
[2014-02-14 22:54:12] |
onnb - Posts: 662 |
I can see that its defined as an unsigned long so I can count on it supporting values up to and including 4294967295 before over lapping?
[2014-02-15 01:18:10] |
much bigger than that: __int64 DLLNameUserServiceLevel; Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
