Date/Time: Thu, 13 Feb 2025 04:04:46 +0000
[User Discussion] - Running Sierra Chart on MAC
View Count: 529
[2020-11-24 13:04:34]
User300273 - Posts: 2
Hi - I've recently set up SC on my Mac and all was well. I went to re-install a chart book template and ended up going further backwards so decided to uninstall and re-install SC.
The issue I have now is the Play on Mac shortcut for SC doesn't launch anything when double clicking. I also have Metatrader on Play on Mac (Wine - not sure if tis the same thing?) which works fine.
As you can probably tell I am not technically minded so any hand holding to get me back on SC would be most welcomed!!
Thanks in advance,
Tobin
