Date/Time: Sat, 12 Sep 2026 13:23:02 +0000
Bonus of the latest version (menu localization)
View Count: 1493
[2020-11-24 09:02:17]
2garin - Posts: 189
Good day support. Updated the terminal to version 2200. I copied _MenuCustomizations. xml_ and remembered you with a kind word. Once again I ask a question: When will the working localization of the terminal appear? I can switch to English, but still.
Date Time Of Last Edit: 2020-11-24 09:06:19
image2200.png / V - Attached On 2020-11-24 09:01:50 UTC - Size: 37.02 KB - 389 views
[2020-11-24 11:43:21]
User186067 - Posts: 1
[2020-11-25 14:15:16]
We apologize for the issue. We are working on this and will get this resolved as soon as possible. For now go back to the prior version you were running. Instructions:
Software Download: Software Rollback Procedure
Date Time Of Last Edit: 2020-11-25 14:16:10
[2021-01-26 01:45:13]
2garin - Posts: 189
version 2222.
When will the "working" Russian localization be available?
[2021-01-26 09:17:55]
This is now supported in that version and higher. Attach here for us the Russian language MenuCustomizations XML file (Located in the Languages subfolder of the Sierra Chart installation folder) you are using and we will make sure the encoding is UTF-8 so it can be properly used.
Or you can change the encoding yourself using the Notepad + + editor:
https://notepad-plus-plus.org/downloads/
Date Time Of Last Edit: 2021-01-26 09:19:05
[2021-01-27 00:46:59]
2garin - Posts: 189
file (MenuCustomizations.xml) taken from your forum.
the file has lost the relevance of the menu.
Date Time Of Last Edit: 2021-01-27 00:49:51
attachmentMenuCustomizations.xml - Attached On 2021-01-27 00:47:26 UTC - Size: 39.34 KB - 806 views
[2021-01-27 05:47:49]
ganz - Posts: 1048
User62522
вместо чартбук предлагаю термин тубус - футляр для чертежей
также может помочь
iconv -f CP1251 -t UTF8 MenuCustomizations.xml -o MenuCustomizations.xml
[2021-01-27 05:53:46]
The updated file is attached. Save this file over the existing one you have and then restart Sierra Chart.
Date Time Of Last Edit: 2021-01-27 05:54:28
attachmentMenuCustomizations.xml - Attached On 2021-01-27 05:53:20 UTC - Size: 46.71 KB - 460 views
[2021-01-28 03:12:47]
User897008 - Posts: 48
Is there a Chinese version?
[2021-01-28 09:52:06]
Yes. Yes these Chinese translation files are supplied with Sierra Chart.
You will want to use the Simplified Chinese version.
We will provide instructions.
[2021-01-28 10:11:13]
George Xia - Posts: 9
翻译 “Menu Items”
在 “Global Settings” 打开-> “Customize Menu Items”
在 “Available Preconfigured Customizations:” 选择翻译文件“MenuCustomizations.SimplifiedChinese.xml”。
点击 “Set” , 和 “是”。
然后 “Ok”
翻译 “Control Bar”
在“Global Settings” 展开“Customize Control Bars” 打开-> “Customize Control Bar 1”
在“Available Languages:” 选择翻译文件“Translation.ControlBar.SimplifiedChinese.xml”
点击 “Set”,和 “是”
然后 “Ok”
