Date/Time: Thu, 13 Feb 2025 03:35:51 +0000
Mini Nikkei 225 OSE HIstorical data
View Count: 728
[2020-11-24 01:38:42] |
Chap - Posts: 39 |
Hi. Please your help I start to use mini Nikkei 225 ose data from CQG, to be able to use historical data they are asking me this you should confirm with Sierra if they have a method for storing historical intraday data. 3 years worth of Daily and above charting. 30 Days of tick data are maintained on the feed. The issue in building intraday charts may stem from not having continuation settings enabled on your username (+$US25/m) however you should confirm this with Sierra before requesting your broker to enable it. I appreciate your confirmation, that I can use that data. Thanks |
[2020-11-24 09:28:55] |
you should confirm with Sierra if they have a method for storing historical intraday data. Yes this is the case.
