Date/Time: Tue, 04 Nov 2025 15:12:38 +0000
SPY options (and Other stocks and ETF)
View Count: 887
|   [2020-11-23 18:52:30]     |
| User968625 - Posts: 260 |
                Hello, I am trying to plot the options I trade and instead of seeing them in IB then I can see them in SC with the instrument I trade (I also do this in TOS). Is there a way to chart options? - Sc is a far better-charting program then IB or TOS and I wish to chart options here as well FYI, options for futures doesn't also work as per the method described in Real-Time Exchange Data Feeds Available From Sierra Chart: Futures Options I use SC All data Thank you  |
|   [2020-11-23 20:45:48]     |
                If you need futures options, install another copy of Sierra Chart  following these instructions: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart You can then follow these instructions: Real-Time Exchange Data Feeds Available From Sierra Chart: Futures Options Regarding options data from interactive brokers, we cannot help with those. Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-23 20:47:29
|   [2020-11-23 22:28:00]     |
                Thanks, I will try this but these instructions for future options didn't work on my current Sc copy. will install a new one but I am not sure if this makes a difference but will try. As for the data with IB, I am not looking to use it. Simply, does stokes and ETF options data available from SC?  |
|   [2020-11-24 04:27:56]     |
                No, we do not provide options for stocks.
                 Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
