Date/Time: Mon, 05 Oct 2026 10:08:18 +0000
[User Discussion] - How draw text underneath bars?
View Count: 1104
| [2020-11-23 11:59:09] |
| User247155 - Posts: 4 |
Hi, Is there any way I can draw text underneath the bars using s_UseTool? I can using subgraphs but I need more than 60 elements. Also, is it possible to offset the text some pixels from the middle of the candle? Thx in advance |
| [2020-11-23 16:42:33] |
| ForgivingComputers.com - Posts: 1239 |
Check the source code for Woodies Panel (scsf_WoodiesPanel) for examples of writing text with s_UseTool.
| [2020-11-23 20:49:10] |
I tried that but offset jumps from one bar to the other one. I need to move the text just some pixels. And still can't find a way to write the text underneath the candlesticks. |
| [2020-11-24 22:49:56] |
Solved, found fix here Using Drawing Tools From an Advanced Custom Study: Drawing Chart Drawings On Top of or Underneath Main Graph and Studies
