DTC Protocol Discussion Forum
Date/Time: Tue, 04 Nov 2025 11:13:55 +0000
[Locked] - DTC HistoricalPriceDataReject
View Count: 2391
[2020-11-23 08:42:45]
RobinhoodFR - Posts: 13
Hello
I am trying to retrieve historical data using the dtc protocol. However I got an issue.
When I send a request, I receive a reject message. Let me give you an example:
[SEND from dtc client] - HistoricalPriceDataRequest - {"RequestID":2,"Symbol":"BN.P.EB","RecordInterval":60,"StartDateTime":1605830400000,"EndDateTime":1605916800000,"Type":800}
[RECEIVED from dtc server] - HistoricalPriceDataReject - {"Type":802,"RequestID":2,"RejectText":"Historical Price Data request is not supported on this port.","RejectReasonCode":4,"RetryTimeInSeconds":0}
By the way, please note:
- Dtc client and dtc server are on the same computer
- I have no major issues using dtc for realtime streaming
- I have followed this: Data and Trading Communications (DTC) Protocol Server: Historical Price Data Server
- I always receive the same error even when changing the record interval
- You will found attached hereto the full log from SC
I do not understand why there is an issue with the port 11098. I also made tests using others ports but I always receive the same error.
Thanks for your answer and your time++
Date Time Of Last Edit: 2020-11-23 08:43:43
Private File
[2020-12-07 02:06:28]
DTC Engineering - Posts: 320
There is a separate port for historical data. You cannot use any other port. Refer to:
You need to use the port labeled "Historical Data Port".
Date Time Of Last Edit: 2020-12-07 02:06:36
