Date/Time: Sun, 24 Nov 2024 12:13:35 +0000
Auto-move target if stoploss is moved
View Count: 950
[2020-11-23 00:47:52] |
User290496 - Posts: 62 |
Hi, Is there a built-in way that would provide the following order modification functionality: I place an OCO order with a stop-loss and two targets. If I move the stop-loss further back manually after the order is placed, can the first target move up automatically in a certain ratio. E.g. I move the stop-loss back two ticks, causing the first target to automatically move up one tick; thus keeping the original risk/reward roughly the same as when the order was placed. |
[2020-11-23 06:41:49] |
There is not direct support for this but it could be developed as a custom study using ACSIL. Refer to: Automated Trading From an Advanced Custom Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-09 17:43:44] |
User200064 - Posts: 31 |
Is this functionality still not supported? If not, could you work on it for future releases? I think is a feature that many users would find valuable, thanks |
[2021-07-04 22:14:37] |
Sierra_Chart Engineering - Posts: 17154 |
We will see if we can get this implemented in the next release.
[2024-05-10 14:42:29] |
kartika1 - Posts: 3 |
Hi, Was there ever implemented? It would be very helpful to automatically move the target order by a certain ratio based on manually moving the stop order.. |
[2024-05-10 15:28:26] |
There is no direct support for this. The only way to do it is to create a custom study.
[2024-06-02 17:28:24] |
Hey there, can you guys create the study? This would be tremendously valuable to a lot of your users
