Date/Time: Tue, 26 Nov 2024 23:28:24 +0000
Setting for Market Depth Window
View Count: 1653
[2020-11-22 06:50:05] |
User50927 - Posts: 91 |
Regarding "Open Market Depth Window" under "Chart", would it be possible to add a "Color Row" highlight setting above a predefined order size? I find that option very useful in your "Open Time & Sales Window" and I could really use it in the Market Depth window to quickly spot large orders at a glance when I use a large number of levels. Thanks.
[2021-08-20 09:51:49] |
User838610 - Posts: 23 |
Hello, how to modify the color of the market depth window ? i need to put red on the bid side and green on ask side. I join a screenshot.
SC change.png / V - Attached On 2021-08-20 09:51:25 UTC - Size: 41.85 KB - 337 views Attachment Deleted. |
[2021-08-20 10:14:45] |
This is explained here: File Menu: Open Market Depth Window (File) From documentation: Market Depth: Bid Gradient Start Color
Market Depth: Bid Gradient End Color Market Depth: Ask Gradient Start Color Market Depth: Ask Gradient End Color Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-08-24 13:46:32] |
User907967 - Posts: 54 |
Hi, is there a way to hide certain columns from the Market Depth Window? For example, can one hide Bid Orders and Ask Orders?
[2023-08-24 14:05:09] |
Sierra_Chart Engineering - Posts: 17187 |
No, that is not supported currently.
[2023-10-10 06:58:36] |
User856504 - Posts: 7 |
Hi there, would like to know whether it is possible to have the feature mentioned in the #1 post (highlighting the order with predefined size) as well.
