Date/Time: Sun, 23 Feb 2025 02:44:23 +0000
the NEW index future: Hang Seng TECH Index Futures (HTI)
View Count: 875
[2020-11-21 06:33:40] |
t39best - Posts: 7 |
https://www.hkex.com.hk/Products/Listed-Derivatives/Equity-Index/Hang-Seng-TECH-Index-Futures-and-Options/Hang-Seng-TECH-Index-Futures?sc_lang=en#&product=HTI The Hang Seng TECH Index Futures (HTI) will be introduced on Nov 23, 2020. Can I see it in Sierra Chart? Thanks |
[2020-11-21 13:50:07] |
We will check on this.
[2020-12-07 07:50:09] |
We apologize for the delay. This is going to be added to the list of symbols in File >> Find Symbol before morning; https://www.hkex.com.hk/Products/Listed-Derivatives/Equity-Index/Hang-Seng-TECH-Index-Futures-and-Options/Hang-Seng-TECH-Index-Futures?sc_lang=en#&product=HTI Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-09 13:34:54] |
Thank you very much!
