Date/Time: Thu, 20 Feb 2025 20:14:25 +0000
Can Inputs for Lines be added to Ultimate Oscillator Study identical to RSI?
View Count: 539
[2020-11-20 18:14:49] |
User14953 - Posts: 241 |
The Study Settings for RSI on the Settings and Inputs Tab list settings for two horizontal Line Values. Input Name Input Value Line1 Value 70 Line2 Value 30 Can Inputs for Lines be added to the Ultimate Oscillator Study identical to the Study Settings for RSI? RSI Ultimate Oscillator |
[2020-11-20 21:02:02] |
John - SC Support - Posts: 38089 |
You really don't need those to be added. You can accomplish the same thing by following these instructions: Chart Studies: Adding a Horizontal Line to an Existing Study You could also modify the source code yourself, as both of those studies are available in the ACS_Source folder under your main Sierra Chart installation. Refer to the information here for how to build a custom study: How to Build an Advanced Custom Study from Source Code For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-21 13:48:49
[2021-01-18 11:18:44] |
Ackin - Posts: 1865 |
User14953) You can download a modified study https://www.sierrachart.com/UserControlPanel.php?page=StudyStore&SCDLLName=zyp_download_free |
