Date/Time: Mon, 13 Jul 2026 13:30:44 +0000
Error connecting to data or trading service
View Count: 777
[2020-11-20 15:43:13]
User645429 - Posts: 4
Good morning,
Have had no problems for months until this morning. Could not connect and getting message about software on host machine causing problems. Have tried firewalls Off but no success.
Here is the message log. Appreciate any guidance. Thank you
Reading Internal Order ID file. | 2020-11-20 09:32:08.951
Reading Trade Orders file. | 2020-11-20 09:32:09.033
Reading Trade Positions file. | 2020-11-20 09:32:09.034
Reading Account Balance file. | 2020-11-20 09:32:09.034
UDPListener (1596). Port 22904 | Listening on UDP port 22904. | 2020-11-20 09:32:09.053
Software version: 2191 64-bit | 2020-11-20 09:32:09.053
Primary Thread ID: 7000 | 2020-11-20 09:32:09.053
Usage end date: 2020-12-05 | 2020-11-20 09:32:09.053
Enabled for: Advanced Features 2. | 2020-11-20 09:32:09.053
Enabled for: Sierra Chart Historical Data Service. | 2020-11-20 09:32:09.053
Enabled for: Denali Real-Time Exchange Data Feed. | 2020-11-20 09:32:09.053
Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-11-20 09:32:09.053
Enabled for exchange2: CME (Trading Account Required) | 2020-11-20 09:32:09.053
Enabled for exchange2: CBOT (Trading Account Required) | 2020-11-20 09:32:09.053
Enabled for exchange2: COMEX (Trading Account Required) | 2020-11-20 09:32:09.053
Enabled for exchange2: NYMEX (Trading Account Required) | 2020-11-20 09:32:09.053
Allow Support for Sierra Chart Data Feeds is enabled. | 2020-11-20 09:32:09.053
Current selected Data/Trading service: CQG WebAPI | 2020-11-20 09:32:09.053
Custom symbol settings values: enabled | 2020-11-20 09:32:09.053
Chart Update Interval: 500 | 2020-11-20 09:32:09.053
Intraday Data Storage Time Unit: 0 | 2020-11-20 09:32:09.053
Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2020-11-20 09:32:09.053
2020-11-20 15:32:09 Local computer time in UTC | 2020-11-20 09:32:09.053
2020-11-20 09:32:09 Local computer time in SC Time Zone | 2020-11-20 09:32:09.053
2020-11-20 15:32:06 Server time in UTC | 2020-11-20 09:32:09.053
Local computer UTC time and Server UTC time difference: 1 seconds. | 2020-11-20 09:32:09.053
Program path: C:\SierraChart\ | 2020-11-20 09:32:09.053
Data Files path: C:\SierraChart\Data\ | 2020-11-20 09:32:09.053
OS Version Number: 10.0 | 2020-11-20 09:32:09.053
Locale Setting: C | 2020-11-20 09:32:09.053
DLLs: DivergenceDetector_64.dll, EdgeTradingGroup.dll, EdgeTradingGroup_64.dll, EminiPlayerIntradaySuite_64 (1).dll, eminiplayer_64.dll, EndedAuction_64.dll, ETG Audio.dll, ETOFSv2.0.dll, ETOFSv2.0_64.dll, ETOFSv3_64.dll, ExahustionDetector_64.dll, JoboPinch_64.dll, LinearRegressionLocation_64.dll, openal32.dll, PivotLine_64.dll, PoorStructure_64.dll, PrevReferences_64.dll, PriceTickDivergence_64.dll, ProfilePeriods_64.dll, ProfileValue_64.dll, ReconstructedTape_64.dll, sst_FreeBundle.dll, sst_FreeBundle_2151.dll | 2020-11-20 09:32:09.054
Allowed protected custom studies: EMiniPlayer, EminiPlayer Intraday Suite, Emoji Trading Order Flow Suite v2, ETG, ETG Audio, Pit - Divergence Detector, Pit - Ended Auction, Pit - Exahustion Detector, Pit - Jobo Pinch, Pit - Linear Regression Location, Pit - Pivot Line, Pit - Poor Structure, Pit - Previous References, Pit - Price Tick Divergence, Pit - Profile Periods, Pit - Profile Value, Pit - Reconstructed Tape, Pit - Statistics Bubbles, Pit - Tick Statistics, Pit - Volume Comparison, Pit - Volume Ticker Comparison, SST_FreeBundle, VerbalJournal | 2020-11-20 09:32:09.054
Created the DTC Protocol server. | 2020-11-20 09:32:09.056
DTC Protocol Server listening on port 11099. | 2020-11-20 09:32:09.058
Created the DTC Protocol historical data server. | 2020-11-20 09:32:09.058
HD Server Manager | Listening on port 11098 | 2020-11-20 09:32:09.059
Checking for new symbol settings. Requested symbol settings MD5 for service code cqg. Request ID: 1. | 2020-11-20 09:32:09.059
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2020-11-20 09:32:09.078
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2020-11-20 09:32:09.388
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2020-11-20 09:32:09.388
Received 5 login tokens. | 2020-11-20 09:32:10.073
Symbol settings MD5 received. Request ID: 1. | 2020-11-20 09:32:10.538
Symbol settings are up-to-date for cqg. | 2020-11-20 09:32:10.538
CQG WebAPI | Connecting to server api.cqg.com | 2020-11-20 09:32:15.596
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2020-11-20 09:32:15.596
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2020-11-20 09:32:15.597
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2020-11-20 09:32:15.597
CQG WebSocket socket (1) | Connecting to IP: 203.192.64.152. | 2020-11-20 09:32:15.597
CQG WebSocket | Opening WebSocket. | 2020-11-20 09:32:15.656
CQG WebSocket | Sending WebSocket handshake. | 2020-11-20 09:32:15.656
Service connection timed out. Will disconnect and retry. | 2020-11-20 09:33:15.592 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-20 09:33:15.592
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-20 09:33:15.592
CQG WebSocket socket (1) | CloseSocket call. | 2020-11-20 09:33:15.608
CQG WebSocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-11-20 09:33:15.608
CQG WebSocket | WebSocket closed. | 2020-11-20 09:33:15.608
CQG WebAPI | WebSocket closed. | 2020-11-20 09:33:15.608
CQG WebAPI | Disconnected. | 2020-11-20 09:33:15.608
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-20 09:33:15.608
CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. | 2020-11-20 09:33:15.608
CQG WebAPI | Connecting to server api.cqg.com | 2020-11-20 09:33:18.624
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2020-11-20 09:33:18.625
CQG WebSocket socket (2) | Creating socket. Using TLS 1.2. | 2020-11-20 09:33:18.847
CQG WebSocket socket (2) | New receive buffer size: 5242880 | 2020-11-20 09:33:18.847
CQG WebSocket socket (2) | Connecting to IP: 203.192.64.152. | 2020-11-20 09:33:18.847
CQG WebSocket | Opening WebSocket. | 2020-11-20 09:33:18.876
CQG WebSocket | Sending WebSocket handshake. | 2020-11-20 09:33:18.876
CQG WebSocket socket (2) | Socket gracefully closed by remote side. | 2020-11-20 09:33:32.890
CQG WebSocket socket (2) | CloseSocket call. | 2020-11-20 09:33:32.890
CQG WebSocket socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-11-20 09:33:32.890
CQG WebSocket | Network socket for WebSocket has been closed by remote side or error. | 2020-11-20 09:33:32.890
CQG WebAPI | WebSocket closed. | 2020-11-20 09:33:32.890
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-20 09:33:32.890
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-20 09:33:32.890
CQG WebSocket socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2020-11-20 09:33:32.890
CQG WebSocket socket (0) | CloseSocket call. | 2020-11-20 09:33:32.901
CQG WebAPI | Disconnected. | 2020-11-20 09:33:32.901
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-20 09:33:32.901
CQG WebAPI | Connecting to server api.cqg.com | 2020-11-20 09:33:35.922
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2020-11-20 09:33:35.923
CQG WebSocket socket (3) | Creating socket. Using TLS 1.2. | 2020-11-20 09:33:35.924
CQG WebSocket socket (3) | New receive buffer size: 5242880 | 2020-11-20 09:33:35.924
CQG WebSocket socket (3) | Connecting to IP: 203.192.64.152. | 2020-11-20 09:33:35.924
CQG WebSocket socket (2) | Write has completed. Shutdown being performed. | 2020-11-20 09:33:38.056
CQG WebSocket socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-11-20 09:33:38.056
CQG WebSocket socket (2) | Closed. | 2020-11-20 09:33:38.057
CQG WebSocket | Opening WebSocket. | 2020-11-20 09:33:38.955
CQG WebSocket | Sending WebSocket handshake. | 2020-11-20 09:33:38.955
CQG WebSocket socket (3) | Socket gracefully closed by remote side. | 2020-11-20 09:33:44.284
CQG WebSocket socket (3) | CloseSocket call. | 2020-11-20 09:33:44.285
CQG WebSocket socket (3) | 0 bytes remaining in receive buffer when socket closed. | 2020-11-20 09:33:44.285
CQG WebSocket | Network socket for WebSocket has been closed by remote side or error. | 2020-11-20 09:33:44.285
CQG WebAPI | WebSocket closed. | 2020-11-20 09:33:44.285
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-20 09:33:44.285
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-20 09:33:44.285
CQG WebSocket socket (3) | Write in progress. Shutdown being delayed. PendingSize=0 | 2020-11-20 09:33:44.285
CQG WebSocket socket (0) | CloseSocket call. | 2020-11-20 09:33:44.296
CQG WebAPI | Disconnected. | 2020-11-20 09:33:44.296
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-20 09:33:44.296
CQG WebAPI | Connecting to server api.cqg.com | 2020-11-20 09:33:47.317
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2020-11-20 09:33:47.317
CQG WebSocket socket (2) | Creating socket. Using TLS 1.2. | 2020-11-20 09:33:47.318
CQG WebSocket socket (2) | New receive buffer size: 5242880 | 2020-11-20 09:33:47.319
CQG WebSocket socket (2) | Connecting to IP: 203.192.64.152. | 2020-11-20 09:33:47.319
CQG WebSocket | Opening WebSocket. | 2020-11-20 09:33:47.347
CQG WebSocket | Sending WebSocket handshake. | 2020-11-20 09:33:47.347
CQG WebSocket socket (2) | Socket gracefully closed by remote side. | 2020-11-20 09:33:55.367
CQG WebSocket socket (2) | CloseSocket call. | 2020-11-20 09:33:55.367
CQG WebSocket socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-11-20 09:33:55.367
CQG WebSocket | Network socket for WebSocket has been closed by remote side or error. | 2020-11-20 09:33:55.367
CQG WebAPI | WebSocket closed. | 2020-11-20 09:33:55.367
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-20 09:33:55.367
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-20 09:33:55.367
CQG WebSocket socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2020-11-20 09:33:55.367
CQG WebSocket socket (0) | CloseSocket call. | 2020-11-20 09:33:55.392
CQG WebAPI | Disconnected. | 2020-11-20 09:33:55.393
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-20 09:33:55.393
CQG WebAPI | Connecting to server api.cqg.com | 2020-11-20 09:33:58.395
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2020-11-20 09:33:58.395
CQG WebSocket socket (4) | Creating socket. Using TLS 1.2. | 2020-11-20 09:33:58.396
CQG WebSocket socket (4) | New receive buffer size: 5242880 | 2020-11-20 09:33:58.396
CQG WebSocket socket (4) | Connecting to IP: 203.192.64.152. | 2020-11-20 09:33:58.396
CQG WebSocket | Opening WebSocket. | 2020-11-20 09:33:58.421
CQG WebSocket | Sending WebSocket handshake. | 2020-11-20 09:33:58.421
CQG WebSocket socket (2) | Write has completed. Shutdown being performed. | 2020-11-20 09:34:06.559
CQG WebSocket socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-11-20 09:34:06.559
CQG WebSocket socket (2) | Closed. | 2020-11-20 09:34:06.560
Service connection timed out. Will disconnect and retry. | 2020-11-20 09:34:58.390 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-20 09:34:58.390
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-20 09:34:58.390
CQG WebSocket socket (4) | CloseSocket call. | 2020-11-20 09:34:58.406
CQG WebSocket socket (4) | 0 bytes remaining in receive buffer when socket closed. | 2020-11-20 09:34:58.406
CQG WebSocket | WebSocket closed. | 2020-11-20 09:34:58.406
CQG WebAPI | WebSocket closed. | 2020-11-20 09:34:58.406
CQG WebAPI | Disconnected. | 2020-11-20 09:34:58.406
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-20 09:34:58.406
CQG WebSocket socket (4) | Shutdown started. Waiting for graceful close. | 2020-11-20 09:34:58.407
CQG WebSocket socket (3) | Timed out waiting for final send. Canceling I/O. | 2020-11-20 09:34:58.922
CQG WebSocket socket (3) | Write has completed. Shutdown being performed. | 2020-11-20 09:34:58.922
CQG WebSocket socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-11-20 09:34:58.922
CQG WebSocket socket (3) | Closed. | 2020-11-20 09:34:58.922
CQG WebAPI | Connecting to server api.cqg.com | 2020-11-20 09:35:01.418
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2020-11-20 09:35:01.418
CQG WebSocket socket (2) | Creating socket. Using TLS 1.2. | 2020-11-20 09:35:01.419
CQG WebSocket socket (2) | New receive buffer size: 5242880 | 2020-11-20 09:35:01.420
CQG WebSocket socket (2) | Connecting to IP: 203.192.64.152. | 2020-11-20 09:35:01.420
CQG WebSocket | Opening WebSocket. | 2020-11-20 09:35:01.449
CQG WebSocket | Sending WebSocket handshake. | 2020-11-20 09:35:01.449
CQG WebSocket socket (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-11-20 09:35:07.789 *
CQG WebSocket socket (4) | Socket gracefully closed by remote side. | 2020-11-20 09:35:07.789
CQG WebSocket socket (4) | Closed. | 2020-11-20 09:35:07.789
CQG WebSocket socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-11-20 09:35:16.569 *
CQG WebSocket socket (1) | Socket gracefully closed by remote side. | 2020-11-20 09:35:16.569
CQG WebSocket socket (1) | Closed. | 2020-11-20 09:35:16.569
Service connection timed out. Will disconnect and retry. | 2020-11-20 09:36:01.437 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-20 09:36:01.437
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-20 09:36:01.437
CQG WebSocket socket (2) | CloseSocket call. | 2020-11-20 09:36:01.454
CQG WebSocket socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-11-20 09:36:01.454
CQG WebSocket | WebSocket closed. | 2020-11-20 09:36:01.454
CQG WebAPI | WebSocket closed. | 2020-11-20 09:36:01.454
CQG WebAPI | Disconnected. | 2020-11-20 09:36:01.454
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-20 09:36:01.454
CQG WebSocket socket (2) | Shutdown started. Waiting for graceful close. | 2020-11-20 09:36:01.454
CQG WebAPI | Connecting to server api.cqg.com | 2020-11-20 09:36:04.471
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2020-11-20 09:36:04.471
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2020-11-20 09:36:04.472
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2020-11-20 09:36:04.473
CQG WebSocket socket (1) | Connecting to IP: 203.192.64.152. | 2020-11-20 09:36:04.473
CQG WebSocket | Opening WebSocket. | 2020-11-20 09:36:04.503
CQG WebSocket | Sending WebSocket handshake. | 2020-11-20 09:36:04.503
CQG WebSocket socket (1) | CloseSocket call. | 2020-11-20 09:36:06.890
CQG WebSocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-11-20 09:36:06.890
CQG WebSocket | WebSocket closed. | 2020-11-20 09:36:06.890
CQG WebAPI | WebSocket closed. | 2020-11-20 09:36:06.890
CQG WebAPI | Disconnected. | 2020-11-20 09:36:06.890
CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. | 2020-11-20 09:36:06.890
Requested symbol settings for service code sc_futures.dtc.trading. Request ID: 2. | 2020-11-20 09:36:06.924
CQG WebSocket socket (0) | CloseSocket call. | 2020-11-20 09:36:06.925
CQG WebSocket socket (0) | CloseSocket call. | 2020-11-20 09:36:06.928
Current selected Data/Trading service: SC Futures Order Routing/Data | 2020-11-20 09:36:06.929
Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-20 09:36:06.955
SC Futures Order Routing/Data | Connecting to the server futurestrading2.sierracharts.com. Port 11098 | 2020-11-20 09:36:07.965
DTC Client socket (5) | Creating socket. Using TLS 1.2. | 2020-11-20 09:36:07.997
DTC Client socket (5) | New receive buffer size: 5242880 | 2020-11-20 09:36:07.998
DTC Client socket (5) | Connecting to IP: 208.185.224.129. | 2020-11-20 09:36:07.998
SC Futures Order Routing/Data | Network connection to server complete. | 2020-11-20 09:36:08.294
SC Futures Order Routing/Data | Starting socket receive thread. | 2020-11-20 09:36:08.294
SC Futures Order Routing/Data | Sending encoding request to server: Binary VLS. Compression: none | 2020-11-20 09:36:08.295
SC Futures Order Routing/Data | Setting DTC encoding to Binary VLS | 2020-11-20 09:36:09.177
SC Futures Order Routing/Data | Sending logon request message. | 2020-11-20 09:36:09.177
Symbol settings received. Request ID: 2. | 2020-11-20 09:36:09.316
SC Futures Order Routing/Data | Received logon response. | 2020-11-20 09:36:09.471
SC Futures Order Routing/Data | Server Name: SC DTC Server. | 2020-11-20 09:36:09.471
SC Futures Order Routing/Data | Server protocol version: 8. Client protocol version: 8 | 2020-11-20 09:36:09.471
SC Futures Order Routing/Data | Connection error: Trade account not assigned. | 2020-11-20 09:36:09.471 *
SC Futures Order Routing/Data | Waiting for socket receive thread to end | 2020-11-20 09:36:09.519
DTC Client socket (5) | CloseSocket call. | 2020-11-20 09:36:09.519
DTC Client socket (5) | 0 bytes remaining in receive buffer when socket closed. | 2020-11-20 09:36:09.519
DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2020-11-20 09:36:09.520
SC Futures Order Routing/Data | Disconnected. | 2020-11-20 09:36:09.520
DTC Client socket (5) | Socket gracefully closed by remote side. | 2020-11-20 09:36:09.811
DTC Client socket (5) | Closed. | 2020-11-20 09:36:09.811
CQG WebSocket socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-11-20 09:36:23.724 *
CQG WebSocket socket (1) | Socket gracefully closed by remote side. | 2020-11-20 09:36:23.724
CQG WebSocket socket (1) | Closed. | 2020-11-20 09:36:23.724
Checking for new symbol settings. Requested symbol settings MD5 for service code cqg. Request ID: 3. | 2020-11-20 09:36:29.120
Current selected Data/Trading service: CQG WebAPI | 2020-11-20 09:36:29.120
Symbol settings MD5 received. Request ID: 3. | 2020-11-20 09:36:30.617
Requested symbol settings for service code cqg. Request ID: 4. | 2020-11-20 09:36:30.618
Symbol settings received. Request ID: 4. | 2020-11-20 09:36:33.089
CQG WebAPI | Connecting to server api.cqg.com | 2020-11-20 09:36:43.069
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2020-11-20 09:36:43.069
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2020-11-20 09:36:43.069
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2020-11-20 09:36:43.069
CQG WebSocket socket (1) | Connecting to IP: 203.192.64.152. | 2020-11-20 09:36:43.069
CQG WebSocket | Opening WebSocket. | 2020-11-20 09:36:43.093
CQG WebSocket | Sending WebSocket handshake. | 2020-11-20 09:36:43.093
CQG WebSocket socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-11-20 09:36:51.747 *
CQG WebSocket socket (2) | Socket gracefully closed by remote side. | 2020-11-20 09:36:51.747
CQG WebSocket socket (2) | Closed. | 2020-11-20 09:36:51.747
File >> Disconnect selected. | 2020-11-20 09:37:42.176
CQG WebSocket socket (1) | CloseSocket call. | 2020-11-20 09:37:42.176
CQG WebSocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-11-20 09:37:42.176
CQG WebSocket | WebSocket closed. | 2020-11-20 09:37:42.176
CQG WebAPI | WebSocket closed. | 2020-11-20 09:37:42.176
CQG WebAPI | Disconnected. | 2020-11-20 09:37:42.176
CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. | 2020-11-20 09:37:42.176
CQG WebSocket socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-11-20 09:37:42.200 *
CQG WebSocket socket (1) | Socket gracefully closed by remote side. | 2020-11-20 09:37:42.200
CQG WebSocket socket (1) | Closed. | 2020-11-20 09:37:42.200
CQG WebAPI | Connecting to server api.cqg.com | 2020-11-20 09:37:45.804
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2020-11-20 09:37:45.804
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2020-11-20 09:37:45.804
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2020-11-20 09:37:45.804
CQG WebSocket socket (1) | Connecting to IP: 203.192.64.152. | 2020-11-20 09:37:45.804
CQG WebSocket | Opening WebSocket. | 2020-11-20 09:37:46.833
CQG WebSocket | Sending WebSocket handshake. | 2020-11-20 09:37:46.833
Service connection timed out. Will disconnect and retry. | 2020-11-20 09:38:45.806 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-11-20 09:38:45.806
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-20 09:38:45.806
CQG WebSocket socket (1) | CloseSocket call. | 2020-11-20 09:38:45.822
CQG WebSocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-11-20 09:38:45.822
CQG WebSocket | WebSocket closed. | 2020-11-20 09:38:45.822
CQG WebAPI | WebSocket closed. | 2020-11-20 09:38:45.822
CQG WebAPI | Disconnected. | 2020-11-20 09:38:45.822
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-11-20 09:38:45.822
CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. | 2020-11-20 09:38:45.822
CQG WebSocket socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-11-20 09:38:46.162 *
CQG WebSocket socket (1) | Socket gracefully closed by remote side. | 2020-11-20 09:38:46.162
CQG WebSocket socket (1) | Closed. | 2020-11-20 09:38:46.162
CQG WebAPI | Connecting to server api.cqg.com | 2020-11-20 09:38:48.829
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2020-11-20 09:38:48.829
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2020-11-20 09:38:49.045
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2020-11-20 09:38:49.045
CQG WebSocket socket (1) | Connecting to IP: 203.192.64.152. | 2020-11-20 09:38:49.045
CQG WebSocket | Opening WebSocket. | 2020-11-20 09:38:49.072
CQG WebSocket | Sending WebSocket handshake. | 2020-11-20 09:38:49.072
[2020-11-20 16:14:31]
John - SC Support - Posts: 47144
Refer to the Frequent Reconnections section in here:
CQG Trading Platform Service: Solving CQG Market Data Feed Problems
