Date/Time: Thu, 13 Feb 2025 02:37:00 +0000
Chart bar expansion or time expansion
View Count: 544
[2020-11-20 14:55:55] |
$teve.00 - Posts: 20 |
Hi, how can i get the chart to keep a constant space between the prices on the right a the current bar? It's something so common on other platforms, I can't find it on sierra. TY http://www.sierrachart.com/image.php?Image=1605884001985.png |
![]() Attachment Deleted. |
[2020-11-20 15:54:35] |
John - SC Support - Posts: 37916 |
Refer to the following: Chart Scale and Scale Adjusting: Using Fixed Values for Top and Bottom of Scale Range For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-21 13:43:11] |
This is the correct documentation for what you want to do: Working With Charts: Right Side Fill Space Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
