Date/Time: Mon, 25 Nov 2024 14:28:13 +0000
Gold Chart weird
View Count: 1367
[2014-02-14 17:00:23]
User88901 - Posts: 33
http://screencast.com/t/INfHecdq67
Why does my volume profile in gold contract look like this? Rbob(gasoline) also looked funny. I am using your data feed through interactive brokers. My Globex symbols work great with the data feed so maybe it is just non-globex symbols I have problems with? Thanks.
[2014-02-14 17:50:05]
If you are referring to the Volume Profile bars being one pixel wide, this has to do with the small tick size relative to the range of prices in the chart.
[2014-02-14 21:33:01]
After thinking about it, it seems I am probably using IB data for this GC contract and not the SC data. Do I need to do subscribe to something else to get the correct volume data? Or is there another gold symbol I can use to get the feed from SC?
[2014-02-14 21:45:39]
Both of these images show the Sierra Chart data feed is being used. To make sure that all the data in the chart is from the Sierra Chart data feed select Edit >>Delete All Data and Download.
