Date/Time: Thu, 13 Feb 2025 02:35:53 +0000
Eurex futures and Nikkei mini futures
View Count: 714
[2020-11-20 10:02:41]
Chap - Posts: 39
Hi.
Now I have Denali Data to trade CME Products, But I'm thinking to be able to Trade Eurex Futures and Nikkei mini, could you explain which method can I use to have the data to trade these products, and with good cost. should I use Sierra charts Data. What is the process to get this data.
[2020-11-23 09:14:11]
For data for the Nikkei Mini, you need to use CQG:
CQG Trading Platform Service
Second, as to the EUREX, you would get the data by subscribing to the Sierra Chart Exchange Data Feed and then enabling the EUREX exchange. You can use both the Sierra Chart Exchange Data Feed and the Denali Exchange Data Feed together. Refer to the information here:
https://www.sierrachart.com/index.php?page=doc/RealTimeDataFeedsAvailableFromSierraChart.php#UsingBothDenaliExchangeDataFeedAndSierraChartExchangeDataFeed
Finally, you would need to check with your broker to see if they support trading of the EUREX through the Sierra Chart Order Routing Service. There are some that do and some that do not.
