Date/Time: Thu, 24 Sep 2026 10:38:19 +0000
Market depth historical graph error
View Count: 755
| [2020-11-20 08:55:20] |
| User351816 - Posts: 3 |
Hi, The bid/offer data displayed on the Market depth historical graph does not line up with dom bid/offers. The bid/offer blocks are very far away from actual bid/offers ( >15 points on ES futures). I have only recently started having this issue (before it worked perfectly) and I am not sure if I have accidentally changed a setting or if this is a data error. I use the Denali data feed but my broker is IB and I use the API connection. http://www.sierrachart.com/image.php?Image=1605862663335.png Date Time Of Last Edit: 2020-11-20 08:57:52
| [2020-11-20 14:33:16] |
| John - SC Support - Posts: 47994 |
You are using a Trade and Current Quote symbol, and if you do not have the option for Use As Trade Only Symbol enabled, then the Chart DOM will be reflecting the market depth for the Trade and Current Quote Symbol, but the Market Depth Historical Graph is still using the data from the primary symbol. Refer to the information here: Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
