Date/Time: Mon, 25 Nov 2024 15:00:33 +0000
TradeIndicator
View Count: 1157
[2014-02-14 15:29:52] |
User39772 - Posts: 311 |
Can you explain the meaning of this field in Quote Board.
[2014-02-14 21:05:39] |
No. It comes from the particular Data service you are using.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-14 21:05:49
