Date/Time: Thu, 13 Feb 2025 03:14:46 +0000
Using Denali data feed
View Count: 463
[2020-11-20 07:57:22] |
aelagha - Posts: 31 |
I am setting up an account with an FCM that supports TT so I can use SC order routing. In the meantime, I want to enable Denali data feed. There are two options: 1- Denali Exchange data feed for SC order routing service (not eligible) 2- Denali Exchange data feed for all services (eligible) I understand I am not eligible for option1 since the live trading account is setup yet. Can I go with option 2 and switch to option 1 later once the account is setup, or would option 1 still work with SC order routing? |
[2020-11-20 07:58:50] |
Can I go with option 2 and switch to option 1 later once the account is setup, Yes this is what you will need to do for now. would option 1 still work with SC order routing?
Yes this is the case.
