Date/Time: Thu, 13 Feb 2025 07:56:45 +0000
Tool question
View Count: 610
[2020-11-20 01:10:27] |
User845052 - Posts: 75 |
is there a tool which allows me to draw a vertical line or other marker that is X ticks long, preconfigured?
[2020-11-20 01:26:37] |
Tool>>Marker>>Square/X/Plus
[2020-11-20 04:42:46] |
Do you still have a question here? Or is post #2 answering your own question?
[2020-11-20 16:23:17] |
Yes, the latter, thanks
[2020-11-25 22:46:24] |
Sc, I take back what I said about the Marker being a solution. It works with some competency but the length/size of the Marker slightly changes when zooming between certain levels. So it is not an accurate, workable solution. Please advise alternatives |
[2020-11-30 15:21:41] |
John - SC Support - Posts: 37916 |
There is a not a built-in tool that will let you set the number of ticks that the tool drawing will cover. The only way to do this would be to use ACSIL. Refer to the following: Using Drawing Tools From an Advanced Custom Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-01 17:53:12
