Date/Time: Thu, 13 Feb 2025 02:47:51 +0000
Remove study graph but keep region data line
View Count: 512
[2020-11-20 00:25:42] |
user459212 - Posts: 12 |
I am looking everywhere for this but don't see it. I know I can just drag the study down and keep the data line showing but I want a way to completely hide the graph portion of the study while keeping the data line. Like in the screenshot, except the study is hidden not just dragged down. Possible?
[2020-11-20 00:33:29] |
You really just have to reduce the height of the Chart Region. As an alternative, we would recommend using this particular study to show the study values as text on the chart: Text Display For Study And then just hide the original study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
