Date/Time: Sun, 08 Sep 2024 00:43:11 +0000
How to see which windows are linked
View Count: 1023
[2014-02-14 14:48:11] |
joshtrader - Posts: 484 |
Let's say I want to establish a new link between two new charts. Is there a way to check to see what links are set up in existing charts, so I don't accidentally use a link that's already being used?
[2014-02-14 15:17:25] |
When you open the CW (Chart Windows) menu, you will see a list of all opened charts. In the name you will see L:#, which is the link number used with that chart. This would be the fastest way to view all the link numbers used.
Sierra Chart Support Date Time Of Last Edit: 2014-02-14 15:17:53
