Date/Time: Thu, 13 Feb 2025 02:32:45 +0000
Trade and Current quote symbol problem
View Count: 542
[2020-11-19 15:25:39] |
User107019 - Posts: 2 |
Hi I am trying to trade Micros using the Mini charts. After reading and setting up the trades are NOT been executed in the Micros as I wish. Please see below attachments and provide some guidelines Regards Leandro |
[2020-11-21 12:47:31] |
You do have the Trade and Current Quote symbol set up properly. There simply is no possibility an order would be sent for a different symbol. Make sure you are submitting orders from that specific chart. Refer to: Chart Trading and the Chart DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
