Date/Time: Thu, 13 Feb 2025 03:03:15 +0000
S&P 500 futures and AMP
View Count: 670
[2020-11-19 15:19:57] |
User819016 - Posts: 9 |
I am using Sierra Chart via an AMP Futures account. When attempting to access the CME S&P 500 futures index (F.US.SPZ20) on the chart, I get a data feed error ("end of day data not supported"). AMP Futures said to contact you to resolve the issue.
[2020-11-20 05:49:04] |
That is not the correct symbol. The correct symbol is: F.US.EPZ20 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
