Date/Time: Wed, 27 Nov 2024 02:21:43 +0000
Options chain using Sierra Denali
View Count: 2265
[2020-11-19 05:08:12] |
Ryan Bailey - Posts: 53 |
Hello I'm using your feed coming over from Rithmic for CME futs. I was trying to figure out if I can pull up and options chain for ES and it's different expiry dates in order to trade them on your platform. Please clarify for me on how to do this. Thanks Ryan |
[2020-11-19 05:47:18] |
You can certainly access the options data. Refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Futures Options Regarding trading them, that is supported but we are not sure whether your broker would support trading options over TT. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-19 21:21:26] |
Appreciate this fast response. I'll def check it out. According to them I am still approved to trade options so I'll take a look and see what the chain looks live via Sierra. Does the options chain you provide still show greeks like delta, theta, and implied volatility?
[2020-11-20 05:39:57] |
Does the options chain you provide still show greeks like delta, theta, and implied volatility? No, this is not supported.
