Date/Time: Wed, 12 Feb 2025 22:17:49 +0000
Adjusting charts to increase number of candlesticks relative to chart size
View Count: 476
[2020-11-19 02:09:38]
bn - Posts: 2
Thanks for reading this.
I use a lot of graphs on a given chartbook and I can only get 50-100 candlesticks per chart and I am trying to increase this number, i.e. minimizing the view of the chart to fit more in on the x axis. I have been snooping around chart settings but it seems as if there is only documentation for range of the y axis.
Thanks.
[2020-11-19 14:43:34]
John - SC Support - Posts: 37916
Refer to the following for how to change the bar spacing:
Working With Charts: Changing Bar Spacing
Also, be aware that there is going to be a limitation on the maximum number of bars that can be seen on the screen at one time. This ends up being limited by the ability for the software to be able to actually draw the bars and not have to resort to some kind of interpolation routine. As such, there are a number of factors that go into this, but essentially if you have each bar at the pixel spacing of your monitor, then that is the best that you can do.
