Date/Time: Wed, 12 Feb 2025 22:12:20 +0000
SC not allowing me to trade one instrument, but allowing others
View Count: 477
[2020-11-18 20:00:20] |
Anapurna - Posts: 10 |
SC allows me to trade MES, M6A, but not MCD (e micro USD/CAD) Why would that be, and how would I enable that? Thanks! |
[2020-11-18 20:16:05] |
John - SC Support - Posts: 37915 |
Look in your Trade Service Log when you try to place an order for the MCD and tell us what message you are getting.
[2020-11-18 20:30:48] |
here you go: SC Futures Order Routing/Data order update (Order reject). Info: TT order update (Rejected). Text: No limits | SenderSubID: **. Text: Parent order. Tag: A SimpleBracket -7 S-+10 T.twconfig. Internal Order ID: 179829. Service Order ID: 3916797. Symbol: MCDZ20_FUT_CME. Account: ** | 2020-11-18 15:24:59.692 * Thank you Date Time Of Last Edit: 2020-11-18 21:33:10
[2020-11-18 21:33:24] |
Contact your broker and let them know you are getting this error for that particular product: Text: No limits They need to set the limits on it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-18 21:33:37
