Date/Time: Sun, 08 Sep 2024 00:37:56 +0000
How To Increase Font Size In Status Bar?
View Count: 1497
[2014-02-14 07:56:10] |
User25633 - Posts: 10 |
How do I increase the font size in the status bar? By status bar I mean the area in Sierra Chart that shows the open, high, low, close, and time of the bar when you move the crosshair. The text is so tiny I can hardly see it. Thank you.
Date Time Of Last Edit: 2014-02-14 08:00:36
[2014-02-14 09:51:35] |
It can be done through Global Settings >> Graphics Settings >> Other >> Text Windows Font. However, we much recommend that you use the Tool Values Windows instead: https://www.sierrachart.com/index.php?l=doc/doc_Tools.html#ViewingToolandChartData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
