Date/Time: Wed, 12 Feb 2025 21:53:12 +0000
SC Installer - Failed - Error Saving Download files
View Count: 563
[2020-11-18 17:30:15] |
User468384 - Posts: 5 |
Hi SC Tech Support, Please help with this error and failure when I try to install SC on my new Laptop system. SC - Installer - Failed > Error saving files to local system |
SC, error install.png / V - Attached On 2020-11-18 17:29:56 UTC - Size: 632.42 KB - 189 views |
[2020-11-18 19:43:56] |
We need to get the Installer log. Instructions: Software Download: Providing Installer Log to Support Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
