Date/Time: Wed, 12 Feb 2025 22:27:35 +0000
Gaps in data
View Count: 457
[2020-11-18 15:07:33] |
User609896 - Posts: 7 |
Hello, After changing package 5 to package 3 - 11.11.2020 there are gaps in the data. See Annex. Support AMP Global wrote me to contact you. Thank you Petr Plachy AC104859 http://www.sierrachart.com/image.php?Image=1605672936607.png |
[2020-11-18 15:24:42] |
We see you are using Rithmic. We have discontinued technical support for Rithmic. And we no longer provide historical data for Rithmic either. You need to use the Sierra Chart Order Routing Service instead: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
