Date/Time: Wed, 12 Feb 2025 22:15:59 +0000
Study displays underneath price bars without it checked
View Count: 720
[2020-11-18 13:59:33] |
Sawtooth - Posts: 4173 |
Using the Spreadsheet System/Alert study, all subgraph draw styles draw underneath the Main Price Graph, despite that 'Draw Study Underneath Main Price Graph' is not checked. Also, the spreadsheet study is at the bottom of the Studies To Graph list, yet its subgraph draw styles display underneath other studies' displays. I'm expecting studies in the Studies To Graph list to overdraw those above it. Please advise. |
Behind bar.PNG / V - Attached On 2020-11-18 13:58:34 UTC - Size: 3.78 KB - 191 views |
[2020-11-18 14:26:25] |
This is because of the particular Draw Style it is using which requires it be drawn first. What specific Draw Styles are being used? We will make it clear in the documentation about this. Assuming it is not there already.
[2020-11-18 22:36:29] |
I'm using Background and Background Transparent, and I like that it draws underneath the Main Price Graph, as it currently does. I'm also using Value On High and Value On Low, and I need these to draw in front of the Main Price Graph. |
[2020-11-18 22:52:15] |
I'm also using Value On High and Value On Low, and I need these to draw in front of the Main Price Graph. In this case you need to use a separate study for these to prevent the study from being drawn underneath.
