Date/Time: Fri, 11 Sep 2026 18:58:17 +0000
Searching for CBOE Europe Equities - Please help [SOLVED]
View Count: 1319
[2020-11-17 15:58:38]
RobinhoodFR - Posts: 13
Hello!
I am new to SC.
I have made a subcription to advanced SC, RT SC and also US equities. This is working fine.
I am know searching for a way to activate CBOE Europe Equities but cannot find how to. I try to search for some european symbols in the SC plateform but without success.
Thanks by advance for your time and your avilibility++
[2020-11-17 16:32:03]
I remember that you told me this data was available:
Euronext Real Time Stocks (Teletrader now only provide 15 minutes delayed)
I need to move fast. Thanks for your answer and your time++
[2020-11-18 09:11:06]
Is it possible to have an answer please?
[2020-11-18 17:41:41]
UP please!
[2020-11-18 20:13:13]
Really suprised by the fact I still have not received any answer... A bug for sure :-)
[2020-11-18 20:26:25]
User390455 - Posts: 56
Hello
Another question is on the same subject.
euronext equity
Sierra Chart must find a new way or solution because of the political change of CBOE.
This take time ! Wait and see.
Date Time Of Last Edit: 2020-11-18 20:30:07
[2020-11-18 20:37:20]
Hi
Thanks for your answer.
It seems that CBOE Europe stocks are no longer provided by SC...??
Moreover I though I may at least have access to LSE stocks but it seems that only the "delayed feed" exist.. I found another way to have it: using IQFeed. But this is all in all very costly only for LSE stocks realtime!
@SC support: could you please clarify? Is there any chances that 1. you will provide the CBOE Europe stocks realtime and 2. LSE stocks realtime?
Thanks for your time, I know it is really previous, as clients as well++
Date Time Of Last Edit: 2020-11-18 20:38:32
[2020-11-18 21:28:36]
We can release real-time data for CBOE Europe equities, and our plan is to set this up over the weekend.
We apologize for the delay. We were just deciding whether it was worth the effort but once we set it up it will be operational and should not require any further work from us.
We do not have access to real-time London stock exchange data. Only delayed.
[2020-11-19 00:03:07]
We have now released CBOE Europe Equities.
Activate the exchange here:
https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures
Pricing is here:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SupportedExchanges
You can search for symbols through File >> Find Symbol >>CBOE Europe Equities
[2020-11-19 07:49:39]
Thanks a lot, well done!
